Port King Posted April 23, 2006 Report Share Posted April 23, 2006 Hey there, I've got a 535 runnin with 22cc domes, two 35mm VM Mik. carbs the intake is Honda 250. V-Force. My question is; I was running 148 main jet. Now i've installed the power jet kit with extra wide bols and Trinity 50W-TI needles. What should i try out for power jet and main jet starting point ? I think there a equation to find your jet size. Your help is very apreciated. Quote Link to comment Share on other sites More sharing options...
lowriderb Posted April 24, 2006 Report Share Posted April 24, 2006 with methanol your usually going to have to drill the jets to make them the right sizes.. did someone do a conversion on them for you or are you just adding the power jets yourself? the average size dump tube/main jet is drill bit size .116 with around a .093 power jet.. though with the bigger motor your probably going to need the dumps and mains to be around .120 and a little smaller on the power jets.. Quote Link to comment Share on other sites More sharing options...
