CRASHTH Posted April 3, 2006 Report Share Posted April 3, 2006 I HAVE AN 02 I HAVE JUST PUT 40 OVER PISTONS ADA HEAD WITH 21 CC DOMES STOCK REEDS AND EXHAUST AND A MOTION PRO TWIST TROTTLE CONVERION MY TORS BOX IS GONE AND THE BIKE WONT REV UP AT ALL IS IT A TIMING ISSUE OR JETS OR IS IT THE LACK OF TORS BOX HELP BEFOR I SELL ! Quote Link to comment Share on other sites More sharing options...
WNARACE Posted April 3, 2006 Report Share Posted April 3, 2006 Have you adjusted your throttle cabe to sync. the carbs, and make sure that they are opening all the way Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 3, 2006 Report Share Posted April 3, 2006 It is a TORS problem. This should answer all of your questions and more. http://www.dfn.com/benkaren/elecfaq.html Quote Link to comment Share on other sites More sharing options...
CRASHTH Posted April 3, 2006 Author Report Share Posted April 3, 2006 THE CABLE ADJUSTMENT IS DEAD ON AND IT IDLES IT JUST WONT REV UP IT JUST BOGS WHEN YOU GIVE IT THROTTLE Quote Link to comment Share on other sites More sharing options...
banshdog Posted April 3, 2006 Report Share Posted April 3, 2006 TORS...... does your bike have the parking brake? is it stuck on? Quote Link to comment Share on other sites More sharing options...
CRASHTH Posted April 3, 2006 Author Report Share Posted April 3, 2006 THE LEVER FOR THE BRAKE IS GONE BUT THE WIRE IS STILL THER AND PLUGED IN Quote Link to comment Share on other sites More sharing options...
banshdog Posted April 3, 2006 Report Share Posted April 3, 2006 Unplug that bitch........ Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 3, 2006 Report Share Posted April 3, 2006 If you read the electrical FAQ I posted for you, it holds your hand through just about any electrical problem you may come across. It specifically tells you how to eliminate the TORS. Go through it step by step and check everything. Sounds like it would be a good thing for you to commit to memory. Quote Link to comment Share on other sites More sharing options...
CRASHTH Posted April 3, 2006 Author Report Share Posted April 3, 2006 I WILL TRY AND UNPLUG IT THE LINK SENT WAS EXCELENT AND FULL OF GREAT STUFF I PRINTED IT OUT TO READ HERE WHILE AT WORK Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 3, 2006 Report Share Posted April 3, 2006 Good, it is definately a TORS problem, so fix it, and let us know how it goes! Quote Link to comment Share on other sites More sharing options...
CRASHTH Posted April 3, 2006 Author Report Share Posted April 3, 2006 THANKS GUYS ILL LET YOU KNOW WHAT HAPPENS I MAY INCOUNTER MORE ISSUES DOES ANY BODY HAVE ANY SUGGESTIONS ON WHAT I SHOULD JET IT TO Quote Link to comment Share on other sites More sharing options...
sheefreak Posted April 3, 2006 Report Share Posted April 3, 2006 Running w/airbox lid on, off, no airbox, stock carbs??? Quote Link to comment Share on other sites More sharing options...
CRASHTH Posted April 3, 2006 Author Report Share Posted April 3, 2006 40 OVER ADA HEAD 20 CC DOMES TOOMEY 2-1 INTAKE STOCK CARBS EXHAUST AND REEDS AND OTHER LITTLE CRAP NO MOTOR RELATED Quote Link to comment Share on other sites More sharing options...
