Its my first time jetting, looking for some help. My bike is stock right now. Tonight Im installing a pro design air filter, pro circuit platinum pipes and silencers and v-force 3 reeds. My elevation is about 500ft to 800ft and the temp is 40-50. Where should i start with my jetting? I run BG 2 stroke oil at 32:1, which i am probably going to lean out to 40:1 from now on.
Any help is appreciated, thanks.
492095[/snapback]
I'd lose the lid to the air box, 330 or 320 mains, needle in stock position.
Might wanna try some 27.5 pilots too with your air screws out somewheres round
1.5 to 2 turns. Make sure your intakes are sealed well also when changing to
the Vforce reed cages. When going from 32:1 to a 40:1 fuel mixture you are actually
making it richer, BTW. Less oil and more gas. Outta run good with either one of those ratios.
:cheers:
Edited by Hilarious
