I was looking at aftermarket clutches and noticed that they don't use the cushon rings for the clutches. The reason i ask is i had the engine on my work bench and decided to pull the clutch apart and the cushons were in lots of little pieces and was curious if i needed to pick up some new ones.
get rid of them you will have to clean the case very good you don't need the cushions. More crap for yamaha to sell you!
485558[/snapback]
you should probably just rebuild the whole clutch if those are torn up :D
