im running 's at sea leavel and i think stock pilot and needle on 4th clip. i have mild port and pro circuits k and n dircect clamp ons and reed spacers. my head is getting milled .025 over will i need to go up on the main or do you think i will be ok?
as long as your not messing with the fuel/air/exhaust/or intake you shouldn't have to mess with the jetting. When you mill the head all it does is bump the compression up which is just how the fuel/air is combusted within the cylinder so you should be fine :cheers:
