hey guys im puttin my 250r together and the end of the sleeve has a piece broken off of it but i put it together ne way and it has good compression will this fuck me in the end?
484701[/snapback]
If the break isn't too severe, you can run it like that without any damage. You risk cracking more though, since you lost the structural integrity of the sleeve as a whole. I've seen them run with some pretty bad breaks and they held up though. It's up to you man. There is an added risk though. If you look on ebay you might be able to find a pretty cheap cylinder and just replace it. :confused:
It would have been good to have taken a die-grinder and clean up the break. That way the harmonic virbration would not be able to form any cracks. Sometimes nothing ever becomes of the break, but if it where mine it would break after about two hours when I was 50miles from home. :angry:
