Here are the specs:
1986 Frame with J-arms
Razr Front (not sure on size) and rear(22x11-9)
ITP Race Wheels front and rear
Also has Rear Geicko Paddles on ITP rims (not race rims)
Motion pro Clutch and Brake Cables
Moose Easy Pull Clutch System
Swing arm extended 2 to 3 inches
All Black Yamaha Factory Plastic with Billet Radiator Cover (Fenders no shaved
Lone star Axcalibar Axle 2 to 4+
Armadillo Bumper
White brothers rear skid plate
White Brother Nerf Bars
Russell Stainless Brakes lines
Braking Stainless Steel Racing Rotors
Braking Semi Metallic Pads
Renthal Gold oring Chain
Renthal Rear Sprocket(42 I believe)
Renthal Front (I believe)12 on the bike? But has another size for it also
Pro Design Shocks on the front with reservoirs
Pivot Works Bearings on all joints on Frame
Tiny Tach Meter
Tether Switch
4 Chrome Lazar lights
2002 Engine (Block was brand new when the engine was built. All engine piece brand new when built. About 3 hours on the bike total over a 3 year period
Pro circuit exhaust (I believe platinum)
Boyeson Rad Valves with power reeds
Wiseco Pistons and bearings
Cometic Gasket kit
Wiseco Hot Rod Crankshaft
DG 34 PJ Carb Kit(Twist throttle, Air boxed removed, K and N filters with extenders)
Pro design Cool Heads with 22 Domes (also has some 19s? or 17s? that have never been installed.
Power-Flow Dirt Valve
Barnett Performance Clutch kit(discs and springs)
Moose Clutch Basket
Hinson Pressure Plate
DynoFS Digital ignition
NGK Plug wires
Pro design Adjustable Stator Plate
Moose High Output Stator(265W)
Will consider all trades for just about anything of matching value.. Since bike was built from ground, I have no title. but do have pictures of the bike being built and have reciept for ebay purchase of frame.
Here are the specs:
Armadillo Bumper
Tiny Tach Meter
Tether Switch
Cometic Gasket kit
Moose Clutch Basket
NGK Plug wires
482261[/snapback]
You mean it's an 87. There is no such thing as an 86 banshee.
