dadoftwins Posted March 5, 2006 Report Posted March 5, 2006 Here are the specs: 1986 Frame with J-arms Razr Front (not sure on size) and rear(22x11-9) ITP Race Wheels front and rear Also has Rear Geicko Paddles on ITP rims (not race rims) Motion pro Clutch and Brake Cables Moose Easy Pull Clutch System Swing arm extended 2 to 3 inches All Black Yamaha Factory Plastic with Billet Radiator Cover (Fenders no shaved Lone star Axcalibar Axle 2 to 4+ Armadillo Bumper White brothers rear skid plate White Brother Nerf Bars Russell Stainless Brakes lines Braking Stainless Steel Racing Rotors Braking Semi Metallic Pads Renthal Gold oring Chain Renthal Rear Sprocket(42 I believe) Renthal Front (I believe)12 on the bike? But has another size for it also Pro Design Shocks on the front with reservoirs Pivot Works Bearings on all joints on Frame Tiny Tach Meter Tether Switch 4 Chrome Lazar lights 2002 Engine (Block was brand new when the engine was built. All engine piece brand new when built. About 3 hours on the bike total over a 3 year period Pro circuit exhaust (I believe platinum) Boyeson Rad Valves with power reeds Wiseco Pistons and bearings Cometic Gasket kit Wiseco Hot Rod Crankshaft DG 34 PJ Carb Kit(Twist throttle, Air boxed removed, K and N filters with extenders) Pro design Cool Heads with 22 Domes (also has some 19s? or 17s? that have never been installed. Power-Flow Dirt Valve Barnett Performance Clutch kit(discs and springs) Moose Clutch Basket Hinson Pressure Plate DynoFS Digital ignition NGK Plug wires Pro design Adjustable Stator Plate Moose High Output Stator(265W) Will consider all trades for just about anything of matching value.. Since bike was built from ground, I have no title. but do have pictures of the bike being built and have reciept for ebay purchase of frame. Quote
BigRed350x Posted March 5, 2006 Report Posted March 5, 2006 Here are the specs:1986 Frame with J-arms Razr Front (not sure on size) and rear(22x11-9) ITP Race Wheels front and rear Also has Rear Geicko Paddles on ITP rims (not race rims) Motion pro Clutch and Brake Cables Moose Easy Pull Clutch System Swing arm extended 2 to 3 inches All Black Yamaha Factory Plastic with Billet Radiator Cover (Fenders no shaved Lone star Axcalibar Axle 2 to 4+ Armadillo Bumper White brothers rear skid plate White Brother Nerf Bars Russell Stainless Brakes lines Braking Stainless Steel Racing Rotors Braking Semi Metallic Pads Renthal Gold oring Chain Renthal Rear Sprocket(42 I believe) Renthal Front (I believe)12 on the bike? But has another size for it also Pro Design Shocks on the front with reservoirs Pivot Works Bearings on all joints on Frame Tiny Tach Meter Tether Switch 4 Chrome Lazar lights 2002 Engine (Block was brand new when the engine was built. All engine piece brand new when built. About 3 hours on the bike total over a 3 year period Pro circuit exhaust (I believe platinum) Boyeson Rad Valves with power reeds Wiseco Pistons and bearings Cometic Gasket kit Wiseco Hot Rod Crankshaft DG 34 PJ Carb Kit(Twist throttle, Air boxed removed, K and N filters with extenders) Pro design Cool Heads with 22 Domes (also has some 19s? or 17s? that have never been installed. Power-Flow Dirt Valve Barnett Performance Clutch kit(discs and springs) Moose Clutch Basket Hinson Pressure Plate DynoFS Digital ignition NGK Plug wires Pro design Adjustable Stator Plate Moose High Output Stator(265W) Will consider all trades for just about anything of matching value.. Since bike was built from ground, I have no title. but do have pictures of the bike being built and have reciept for ebay purchase of frame. 482261[/snapback] You mean it's an 87. There is no such thing as an 86 banshee. Quote
