LaegerBanshee Posted March 4, 2006 Report Share Posted March 4, 2006 Here's the deal. I completed my Laeger Banshee last October (QOTM in Oct) and took the motor through the break in process without any issue. The bike ran fine, never had any issue, only went through about 2 tanks of gas. I put it up for the winter and decided to take it out for a spin today because the weather was good. It started right up on the 2nd or 3rd kick, but I noticed it was running odd at idle as I revved the motor. The left cylinder is running fine but the right seems to be really weak. I got it warm and tried to ride it 3 times and it just will not run at all (hoping to clear it out). I changed the plugs, made sure both carbs were getting gas. Granted the gas is about 5 months old, but I wouldn't think it would make that big of difference. I'm pissed because I invested $3K in the motor (full Duncan setup) and I haven't even run the damn thing. I'm going to get it compression tested, but what else should I look for? Has anyone else had this problem? Any thoughts or suggestions would be greatly appreciated. Thanks! Quote Link to comment Share on other sites More sharing options...
Wallrat Posted March 4, 2006 Report Share Posted March 4, 2006 Clean the carbs and put new gas in. Problem solved. Quote Link to comment Share on other sites More sharing options...
suzuki0702 Posted March 4, 2006 Report Share Posted March 4, 2006 was there a large change in temps?? if so your jetting has changed...no probs dude..something very simple im sure...later! Quote Link to comment Share on other sites More sharing options...
LaegerBanshee Posted March 5, 2006 Author Report Share Posted March 5, 2006 Temp has not changed dramatically from when it was last run. Maybe 25 degrees cooler. I'm going to drain all the fuel and flush the carbs and give it another shot. Hopefully, that will do the trick. I have so much invested in it, I almost don't want to ride it! Quote Link to comment Share on other sites More sharing options...
