LaegerBanshee
Everything posted by LaegerBanshee
Looking to setup my Banshee with new fenders. I really loved the look of the 2006 50th Anniversary Yellow and Black setup. Not really sure which model this setup is for on the parts lists. I would think it would be either the Banshee SP (YFZ350SEV) or Banshee SV (YFZ350SPV). None of the parts list the color of the fenders, but I want to make sure to get the Yellow setup. Any help/advice on part numbers or model info would be greatly appreciated. Thanks!
Does anyone know have or know of where I can get new, take off stock Banshee motor? Have a chance to pickup a Banshee with a blown motor on the cheap. Thanks!
I'm selling my Laeger ProTrax Duncan Racing Banshee which I finished in Oct. 2005. Bike has been sitting on the stand since then and it still has the "tits" on the tires. Asking $7,000 and I'm not looking for any trades. Bike is located roughly 50 miles west of Richmond, VA. Pics can be seen by looking at the Oct. 2005 Quad of Month listing. The bike was sold, but the deal fell through, so it is crated up and ready to go. Email me if you have any questions. Here are the specs: Frame: 98 Laeger Pro-Trax Banshee (250R Geometery) A Arms: Laeger Pro-Trax (+4) Swingarm: Laeger Pro-Trax CR500 Steering Stem: Laeger Pro-Trax Stbilizer: PEP Axle: RPM Dominator Carrier: Lonestar Locknut: Lonestar Hubs F|R: Stock Bars: Tag T2 Throttle/Clutch Lever: Stock Thumb with Duncan Racing Billet Cover/PEP Grips: Scott Nerfs: AC Propeg Bumper: Duncan 250R Grab Bar: AC Front Shocks: PEP Triple Rate ZPS Rear Shock: PEP CR500 ZPS Brake Lines: Crown Rotors F|R: Braking Rims F|R: Douglas Red Labels Tires F|R: Holeshot 20X6X10 MXR, Holeshot 18X10X8 MXR4 Body: Plastic: Stock 89 (Front & Rear), Stock 99 (Tank & Radiator) Graphics|Seat Cover: Duncan Rear Fender Decal Kit, QuadTech Seat Cover Number Backgrounds: Duncan Racing Handguards: PowerMadd Bar Pad: Tag Fuel Tank: Stock Engine|Drive System: Cylinder|Head: Duncan Racing National Porting with Duncan Racing Powerhead Bore & Stroke: Stock Displacement: 350cc Carburetor: Dual 34 Keihin Carbs with Duncan Racing Pyramid Reed Valves & Master Flow Intake Manifold Air Filter|Box: K&N with DRI Outerwear/Stock AirBox with ProDesign/Custom Carbon Fiber Air Boot Pipe|Silencer: Paul Turner Midrange Pipes & Fatboy Silencers (Triple Plate Chrome) Clutch|Plates: Hinson Billet Clutch Basket & Duncan Racing C33 Clutch Kit (7 Plate) Gearing F|R: 15/39 CDI|Killswitch: Stock Cooling: Stock 98 Radiator Other: Duncan Racing Adjustable Timing Plate, Flywheel Mod, Shift Star Mod, Duncan Racing Billet Water Pump Cover, Billet Water Pump Impeller, Duncan Racing Quick Change Clutch Cover, Duncan Racing Billet Stator Cover, Pro Design Billet Shifter, Hinson Billet Brake Pedal, White Bros. Billet Kick Starter, Cascade Billet Radiator Grill, Cascade Billet Dip Stick, Cascade Billet Rear Master Cylinder Cap, Duncan Billet Parking Brake Block Off Plate, Cascade Billet Exhaust Clamps, UPP Chain Slider Kit, Billet Front Brakeline Clamps, CR500 Linkage, ProTec Full Body Skid Plate Thanks!
I'm selling my Laeger ProTrax Duncan Racing Banshee which I finished in Oct. 2005. Bike has been sitting on the stand since then and it still has the "tits" on the tires. Asking $7,500 OBO and I'm not looking for any trades. Bike is located roughly 50 miles west of Richmond, VA. Pics can be seen in my gallery associated with my profile. Email me if you have any questions. Here are the specs: Frame: 98 Laeger Pro-Trax Banshee (250R Geometery) A Arms: Laeger Pro-Trax (+4) Swingarm: Laeger Pro-Trax CR500 Steering Stem: Laeger Pro-Trax Stbilizer: PEP Axle: RPM Dominator Carrier: Lonestar Locknut: Lonestar Hubs F|R: Stock Bars: Tag T2 Throttle/Clutch Lever: Stock Thumb with Duncan Racing Billet Cover/PEP Grips: Scott Nerfs: AC Propeg Bumper: Duncan 250R Grab Bar: AC Front Shocks: PEP Triple Rate ZPS Rear Shock: PEP CR500 ZPS Brake Lines: Crown Rotors F|R: Braking Rims F|R: Douglas Red Labels Tires F|R: Holeshot 20X6X10 MXR, Holeshot 18X10X8 MXR4 Body: Plastic: Stock 89 (Front & Rear), Stock 99 (Tank & Radiator) Graphics|Seat Cover: Duncan Rear Fender Decal Kit, QuadTech Seat Cover Number Backgrounds: Duncan Racing Handguards: PowerMadd Bar Pad: Tag Fuel Tank: Stock Engine|Drive System: Cylinder|Head: Duncan Racing National Porting with Duncan Racing Powerhead Bore & Stroke: Stock Displacement: 350cc Carburetor: Dual 34 Keihin Carbs with Duncan Racing Pyramid Reed Valves & Master Flow Intake Manifold Air Filter|Box: K&N with DRI Outerwear/Stock AirBox with ProDesign/Custom Carbon Fiber Air Boot Pipe|Silencer: Paul Turner Midrange Pipes & Fatboy Silencers (Triple Plate Chrome) Clutch|Plates: Hinson Billet Clutch Basket & Duncan Racing C33 Clutch Kit (7 Plate) Gearing F|R: 15/39 CDI|Killswitch: Stock Cooling: Stock 98 Radiator Other: Duncan Racing Adjustable Timing Plate, Flywheel Mod, Shift Star Mod, Duncan Racing Billet Water Pump Cover, Billet Water Pump Impeller, Duncan Racing Quick Change Clutch Cover, Duncan Racing Billet Stator Cover, Pro Design Billet Shifter, Hinson Billet Brake Pedal, White Bros. Billet Kick Starter, Cascade Billet Radiator Grill, Cascade Billet Dip Stick, Cascade Billet Rear Master Cylinder Cap, Duncan Billet Parking Brake Block Off Plate, Cascade Billet Exhaust Clamps, UPP Chain Slider Kit, Billet Front Brakeline Clamps, CR500 Linkage, ProTec Full Body Skid Plate Thanks!
When they were originally made, Laeger offered them using either 250R components or Banshee components, so it depends. Both use the 250R geometry. As far as the radiator goes, you will probably have a pretty tough time trying to fit an oversized radiator on the bike. One of the toughest things you are going to run into are air snorkles for the air box to route around the CR500 link shock. Mine are carbon fiber that I purchased from Kellner Motorsports in PA. Another issue is that the banshee fenders have to be trimmed to fit over the front shock mounts and the radiator (as it sits higher). It's a bit of work, but there's nothing like it once you get it finished.
Banshee Motor Woes - Need Advice
LaegerBanshee replied to LaegerBanshee's topic in Banshee Repairs and Mods
Temp has not changed dramatically from when it was last run. Maybe 25 degrees cooler. I'm going to drain all the fuel and flush the carbs and give it another shot. Hopefully, that will do the trick. I have so much invested in it, I almost don't want to ride it! -
Here's the deal. I completed my Laeger Banshee last October (QOTM in Oct) and took the motor through the break in process without any issue. The bike ran fine, never had any issue, only went through about 2 tanks of gas. I put it up for the winter and decided to take it out for a spin today because the weather was good. It started right up on the 2nd or 3rd kick, but I noticed it was running odd at idle as I revved the motor. The left cylinder is running fine but the right seems to be really weak. I got it warm and tried to ride it 3 times and it just will not run at all (hoping to clear it out). I changed the plugs, made sure both carbs were getting gas. Granted the gas is about 5 months old, but I wouldn't think it would make that big of difference. I'm pissed because I invested $3K in the motor (full Duncan setup) and I haven't even run the damn thing. I'm going to get it compression tested, but what else should I look for? Has anyone else had this problem? Any thoughts or suggestions would be greatly appreciated. Thanks!
EC 1992 Rebuilt Banshee with Title!
LaegerBanshee replied to LaegerBanshee's topic in For Sale - Parts & Accessories
Price lowered to $3,500 -
I cannot post the pics. Here's a link: http://www.exriders.com/vbb/showthread.php...threadid=202398 -
1992 Yamaha Banshee Rebuilt in spring 2005. Frame & A-Arms have fresh YFZ Blue Powder Coat. Engine had new rings installed and has about 3 hours riding time since rebuild. Modifications: Motor: Hinson Clutch Cover UMI Chrome Billet Water Pump Cover UMI Chrome Billet Stator Cover Pro Design Cool Head w 22 cc domes (NEW in spring 2005) Duncan Racing Paul Turner High Rev Pipes & Silencers Duncan Racing Pyrmid Reed Valves (NEW in spring 2005) Trinity 2 into 1 Carb Kit with 34 Keihin Carb Pro Desing Pro Flow Filter Kit with New K&N Filer and Wrap Chassis: Laeger +2 A Arms, Std Travel Ohlins Front Shocks Stock Rear Shock (I had leave something stock) Lonestar Round Housing Std Lenght Swingarm RPM Dominator Axle (NEW in spring 2005) Stock Plastics (NEW in spring 2005) Duncan Racing Seat Cover & Graphics Kit (NEW in spring 2005) AC Pro Peg Nerfs (new nets) AC Grab Bar AC Full Body Skid Plate (NEW in spring 2005) New Holeshot MXR 4 Front & Rear Tires on Douglas Wheels Asking $4,000. Email me with questions, the bike is located near Richmond, VA. I'm the original owner, and I have the paperwork to prove it. This bike has never been raced or wrecked, it's a trophy/play quad. I won the October 2005 Blingstar Quad-of-the-Month contest, so I do not mess around when I build quads. The pics pretty much say it all. Thanks!
Blingstar Quad of the Month
LaegerBanshee replied to LaegerBanshee's topic in General Banshee Discussion
I wasn't talking about lack of sales. I was referring to the poor reviews on the Banshee from the so called "experts" at the mags. They would rate a 400EX as a better machine??? Come on, you were fine with getting the same Banshee every year with the only changes being graphics and fender color choices. That was bogus, Yamaha should have stepped up and updated it in 12 years. I do agree with you on the Tree huggers. They, along with the folks at PETA should be shot. -
I don't think I get in any mags. I just want to see a banshee as the winner, instead of another 4 stroke. I'm pretty sure a banshee has never won. -
I'm just trying to get the "non believers" to see the light. If you don't advertise, you'll never get anywhere. If more people sang the praises of the Banshee, then maybe it would be in the lineup for next year. Or at least, Yamaha would have made some changes other than "bold new graphics". -
Banshee fans I need your help. Once again a Banshee is getting the shaft from all the 4 Stroke Lovers and not the respect it deserves. Please vote for my Banshee over on www.exriders.com. Here's the link: http://www.exriders.com/vbb/showthread.php?threadid=183251 Thanks!
I'm in the process of building a laeger banshee. I want to put all read stock fenders, but I'm not sure of the best front/rear and side cover combination to use. It looks like the 99 front & rears are called "romantique red" which appears to be the same as the side covers on the 96 model. Does anyone else have an all red banshee and if so what year fender combinations did you use? Any suggestions? Thanks!
