Sheeboy12 Posted February 8, 2006 Report Posted February 8, 2006 This adjustment cost me 2 motors , because the left screw wiggled loose from vibration and prevented raw fuel from reachin the bottom end. Any way i was wondering what yall recomend (in general) these screws to be set at. Oh and i shaved my head, got reed spacers, and a boost bottle on top of .60 over, clamp ons, and DG pipes. Do i need to rejet? What size jets do yall run (in general) ??? Quote
watkins Posted February 8, 2006 Report Posted February 8, 2006 Sounds to me like you are talking about the idle screw... is this a big screw thats sticking out at a 90 degree angle off the side of the carb? Or are you talking about the small airscrew thats at like a 45 degree angle? Quote
sheefreak Posted February 8, 2006 Report Posted February 8, 2006 There is no in General. Never had DG's, but w/clam on's I would go up a pilot jet to 27.5, lowere the clip one position on the needle, and start around 300-310 on the mains to be safe. Should be a fairly good starting point. Quote
