kawiking Posted February 3, 2006 Report Posted February 3, 2006 im putting my shee together and forgot how the reserve lines go. the 1 from the radiator neck goes to the top of the reserve, i cant remember how the one on the case and the 1 on thepump cover go. any help would be great thanks Quote
kawiking Posted February 3, 2006 Author Report Posted February 3, 2006 the hose on the case is a vent hose isn't it, so does the hose on the water pump cover go back to the bottom of the reserve?? Quote
Ruko Posted February 3, 2006 Report Posted February 3, 2006 The one on the bottom of the reserve goes to the radiator, the one on the top of the reserve goes back up to the front, over the steering stem and back down the other side as the over flow. That is the one that leaks coolant out onto the pipes when it overheats. The hose off the water pump and the case vent hook together into a three way "T" connecter just above / in between the carbs. Quote
