Hey...im fairly new to this form and did a search but didnt realy find what i want.I know no one can tell me exaclty what my jetting should be but im jsut wondering what a good starting point for my new mods are...i put on fmf fattys with powercore 2 silencers and removed airbox and put on k&n pod filters with outerwear...Our weather has been pretty mess up latey so the temp ouside is like -10 to +10 celcius..i was thinking of starting with maybe 330's ?
Probably would get a lot more posts in the Jetting/Exhuast forum but.... With those mods I would expect you'll be somewhere in the low 300's. Say 320 as a good starting point, but you may end up higher. I understand that the FMF's tend to like a stock pilot for your temp around 10C (~50F), however you may want to go up one size on the pilot for -10C. If you're running the stock needle I would guess you'd be between the 3rd and 4th clip. For the temp swings you are talking about, you should most likely be rejetting if it is +10C one day and -10C the other.
