onebanshee Posted January 12, 2006 Report Posted January 12, 2006 I have a '98 Chevy Silverado, 1500, and i think my fuel pump is about to die, has anyone or does anyone know how much it is to fix, and if its hard to do by yourself. Thanks Quote
dirtplay1975 Posted January 13, 2006 Report Posted January 13, 2006 its not too awfully hard to do. The pump could be in the range of $100-$250 and you either pull the gas tank down, or if u can get 3 or 4 friends you can pull the 8 bed mounting bolts as well as a couple ground straps and unplug the tail light wiring and lift off the bed and it is easy to get it. With some help it can be done in an hour or a little longer. I prefer to pull the bed myself since it is relatively easy to do ant it never seems a pump goes out on an empty tank Quote
Robert Posted January 13, 2006 Report Posted January 13, 2006 Whats your truck doing to make you think the fuel pump is going out? Quote
