im runnin a 400cc cheetha kit . so far i have completely blown apart my stock hub and boss when i first got it running, so then i up graded to barrnett
set up with heavy duty dirt diggers. about every 6 months i need to change clutches because they start to slip. need to know if anyone know where to find good clutches that will last a while. theres got to be some out there im sure the big boys with the high horse power dont change as much as i do. ive always ran the same oil since it was stock. silklone never had problems with clutches until i went big bore.
any help would be great. thanks
All you need to do is call Jeff at FAST racing. His screen name here is FASTOYS. He has what you need :cheers:
458012[/snapback]
I'll second the recommendation!! :cheers:
