Handyman Posted December 20, 2005 Report Posted December 20, 2005 OK I'm not sure what I did but it now runs like it's on NOS. I took everyone's advise on my last post and did a few things.... refer to....http://www.bansheehq.com/forums/index.php?showtopic=54099 ANyway here is what I did.. I took the spark plugs and swapped them from left to right, swapped the plug wires from left to right, took the carbs off and swapped the reeds from left to right. While the carbs were of I opened up the fuel bowls and visually checked for dirt and there was none. tapped the carbs on the ground to try to see if anything was knocked loose and I didn't see anything come loose. I put everything back together and took it for a quick spin down the street without the filters on, huge difference. I noticed a difference right when I started it and I noticed the exaust on the left side was considerably stronger than before. Put everything back together and took it for a spin and what a hell of a difference. I think the reeds are shot. So payday I'm buying some new reeds. I want to thank everyone for all the advise that you all offered. Now maybe I'll get the GPS out and see what this thing tops out at. I hope I can help you all out when needed when asked. thanks again. Quote
ogre03 Posted December 21, 2005 Report Posted December 21, 2005 Good to hear you got it going! Even if you aren't sure what you did! Quote
