You need a rebuild as soon as your buddies start beating you on their hondas, J/K.
Depends how much you ride, how well you maintain your quad.
If you got sooty tailpipes you may need to rering or stick in a new top end.
In my case I stuck in a new crank w/pistons, should be good for another 5years
Try the search feature at the top right side of the page. I ride probley 7 hours a month (alot more in the summer) and I will have had the factory pistons and rings in for 2 years on the 27th of December. Tips for long engine life: change tranny fluid alot, clean air filter after every ride, use good mixing oil, use correct octane, and have the correct jetting.
