After my bike sits for awhile ( a few weeks ), when I pull the clutch lever in, the lever will stick. So to release it I have to tap on the part that is on top of the case ( it is the part that you line up the arrows on to adjust your clutch ). I have to do that a couple times before the clutch will release properly. After that it works just like it should. Are the clutch springs bad or is it something else? The clutch is only a couple years old. Thanks.
