on the V-foce model, the reed side of the manifold is machined smooth since the Vforce reed cage has a built in air diverterto direct the air down thought the reeds. the standard version for stock reed cages have an air deflector plate mounted on the reed side to channel the airflow. I learn that the hard way and had to grind off the plate to fit after I realized I ordered the wrong one.
