Hey guys, I have stock banshee with fmf gnarlys/turbine core2's coming and k&n clamp ons all stock in biloxi, mississippi, I think my elevation is 33ft/10m?.. is 350 mains correct(it's what I gathered about from the jetting faq)? Also gargamel told me not to waste my money on a jet kit and get just the jets.
Where can I buy just the jets online?
thanks in advance. :cheers:
Edited by dadudeinbiloxi
Magicracing.com or Dennis Kirk. Magic has the jets separate and dennis kirk
has them in pairs. 350 sounds like it may be a good starting point. You may
need to get some smaller jets too. On down to say 320 or so for when
it starts warmin' up outside.
445971[/snapback]
Thanks hil, good idea I will do that. Don't I need pilots also? What's a good size for them? 27.5? Or do I just need mains?
Fmf recommends a 30 pilot. I got 30's and they made my idle circuit rich.
Right now I'm runnin 27.5's. My bike starts usually 2 to 4 kicks, if the carb
bowls arent dry and will sit and idle a long while w/o turnin the plugs black.
I'd get some 27.5's and adjust your air screws, starting 2 turns out, until
u have a crisp off throttle response. :cheers:
If you havent already, get several sets of spark plugs too. Cause your gonna
need to do a plug chop or too.
I'll go with the 320 and 27.5 then sounds like about right. :cheers:
Do I need that main jet wrench I see on magicracing.com for the main jets too? For installation? I want to make sure.
Screw it I got it anyways just to be safe. Ok.I'm broke for now. I think that covers me though... :cheers:
All you need is a phillips head screw driver and a 6mm socket to change your mains. To get to the pilot, you'll need like one of those small flat head screwdrivers like what comes in an eyeglass repair kit or what not.
446024[/snapback]
Awesome, I got the 6mm wrench they had for sale for the main and i got the 27.5 pilots, should be pretty good then. :cheers: I should have pics up next week.
