aguita Posted December 5, 2005 Report Posted December 5, 2005 Im planning on gettin a ada head with 19cc domes do i need to weld my crank or something or just plug and play??? Quote
dlnoss Posted December 5, 2005 Report Posted December 5, 2005 You are probably fine with a stock crank but I would ask the folks at ADA to be sure. Race gas is probably going to be in order also. I'm sure they can help you with dome selection based on your other mods and your elevation. Quote
aguita Posted December 5, 2005 Author Report Posted December 5, 2005 can i use a 50/50 on race and premium? Quote
ogre03 Posted December 5, 2005 Report Posted December 5, 2005 Once again you will need to talk to them. If you tell them your elevation and other mods (as dlnoss said) and let them know you want to run a certain percent race gas to premium mixture, they will be the ones to tell you what size domes you need to run with their head in order for it all to work together. Quote
aguita Posted December 5, 2005 Author Report Posted December 5, 2005 the thing is that i found this head on ebay for cheap and it comes with those domes..but nvm i can affort race gas Quote
Ducman Posted December 5, 2005 Report Posted December 5, 2005 If you are blow 1000 ft elevation with 19cc domes you will need to run race fule mixed 50/50 with pump fuel. Quote
