Whats up.. Need anouther opinion, I bought the trinity IV manifolds and I was liiking at the inside of them where the rubber boot is that goes over your carb.. well anyway there is a lip on the bottom, right next to the boot on eash manifold. Looks like it would cuase the gas to build up.. was thinking about porting it down so the whole thing will flow nice, I can port and polich thats easy but needed some edvise to see if anyone else had this proplem or are they best like that..?
Edited by 99Banshee
does the lip stick out into the id of the carb. if you put the carb on it, and lift the slide, do you see the lip? the lip is there i am sure to keep your carb from falling in, so i would leave it unless it is in the way of the inlet. just my .02
