what do tors do i hear u guys talking about them all the time what does it do
437080[/snapback]
TORS(Throttle Over Ride System) the main purpose of this is to keep you engine from blowing up if one slide gets stuck in the open position. There are sensors on top of each carb that senses the position of the slide in the carb. There is a sensor in the throttle housing that senses the position of the throttle. The sensor in the throttle housing and on top of the carbs sends a signal to a box(Located under the gas tank on the left side of the frame). When the position of either carb or the throttle position and carb slide positions don't match then the box will send a signal to the ignition box and the ignition will be adjusted to keep your engine from blowing. In another words......get rid of it because when it gets wet enough it will reak havoc and become a huge headache. Plus when you get rid of it and put in a TORS eliminator kit the throttle response becomes alot better.
it kills you....slowly....remove it before its too late.  :ph34r:
437099[/snapback]
lol...I should have said.....Question-What are tors..Reply- They are a bad ass upgrade that only limited banshee's came with they are like a turbo that when you give it gas it spools up increasing your gas and air mixture giving you at least 6 psi. of boost...you are so lucky man gd you, were you live im taking your shit
437144[/snapback]
haha. tors is a turbo. :rotflmao:
