how many quarts are u putting in? i use an 80wt gear oil. thick and cheap and i change it frequently depending on how hard or long i push my bike. i use about 2 n a half quarts i think. . . . . .don't forget to check ur dipstick. thats what they're for!
If you've got a metal to metal sound coming from the trans you're just hiding the problem if you're going to change oils until it goes away. Have it looked at ASAP.
Wouldn't you rather spend a few bucks getting it fixed now before it grenades your engine case and/or transmission gears?
This isn't the time to get cheap.
Rooster :dance:
