This topic has come up in the past and I have found very few individauls that have figured out a simple way to hook up a kill switch using the RZ components.
After several searches that gave fuzzy answers I reviewed the RZ manual and discovered it is very simple.
Hook up:.
Assuming you are using a Banshee key switch hook the black wire from the key switch to one of the post on the ignition coil. (The other post has a orange wire going to the CDI) You then take your black /white wire that also runs off your key swith and connect it to ground.
That simple, Varified results tonight!! Ready to get her fired up next month.
Thanks for listening.
Chris
  • 1 year later...
