Ryda85 Posted October 14, 2005 Report Posted October 14, 2005 ok guys i finally went to put on my new tusk rear rotor and i could not get the caliper to slide on the rotor. too k the rotor back off and it seems to be thicker than stock....which i guess is good for durability but what do i do now? do i need new pads? please help asap. thanks Quote
chris642 Posted October 14, 2005 Report Posted October 14, 2005 not sure if you are a new to brakes so i will point out the obvious. did you push the piston in?? Quote
Ryda85 Posted October 14, 2005 Author Report Posted October 14, 2005 well i am pretty new to brakes but the piston is all the way "in the caliper" meaning not puting any pressure on the pads. i cant get this dam thing on. it slides right on the thinner stock rotor Quote
ozbanshee Posted October 14, 2005 Report Posted October 14, 2005 HAVE A LOOK AT YOUR BRAKE PADS, DOR THEY HAVE A HEAT SHIELD CLIPPED ONTO THE BACK? IF SO POP THE SHIELD OFF THE OUTER PAD SHOULD GAIN YOU ABOUT 1MM IF FITTED. I HA DTHIS PROBLEM WITH ONE SET OF PADS I BOUGHT Quote
