i have t5's with k&n pod filters i was wanting to know which size jets. i got the kit from vitos. it came wiht 280's and 300's.. i was thinking the 300's with the clip at the 4th one from the top. also i noticed one of the needles are barely bent like more of a ding in it instead of a bend near the tip. so how could that affect it.. i mean its not much of a dent but its enough to notice, its just i figured it would be ok since it still went down in the hole straight
It also really depends on your elevation and temp. In Florida I assume your near sea level (don't know I'm from west coast), and probably around 80 degrees or so. With that setup I would also guess around 310 maybe 320 depending on your individual bike. I run my Toomey needle in the 4th position, but it should definitely be 3rd or 4th. Probably 27.5 pilot at 2 turns or so. :cheers:
yeah your correct, its around 80, maybe 76 cause its getting cooler, but its not the toomy needles anyore. thayre pink lookin needles, i got them from vitos. they look a lot different than the ones i took out. and im not shure if it was toomy needles to begin with. all i know is that thayre silver and kinda slim compared to the vito ones
okso 300-310 or so main 4thclip on the needle twards the bottom and what actual size would you say on the pilot..
thanks alot you guys are awesome
