alright im just wondering if there is any major conflicks with running wheel spacers up front.. if i were to run spacer i would be running the dura blue...i would also flip my rims.... would this be ok to run? had anyone ran them and got a review or anything.... are they trustable
Back in the day I flipped the front wheels. It does ride a bit harsh with the extra leverage on the shocks. Wheel spacers add weight. If it is a money issue flip the rims. Drill a hole on the other side and pull a new valve stem through. You can plug the old hole by reversing the valve stem where it is facing inside.
  • 1 month later...
423615[/snapback]
I just tried to return your PM....But had problems...
This message can not be sent because the recipient does not have permission to use the personal messenger or their personal messenger inbox is full.
