Hey all.
Since last weekend i have some new road tires.
These are quite a bit lower then stock 20" banshee tires.
And are an awesome improvement on pavement.
The first response from the riding mates was, your going to be alot slower with those tiny tires.
Boy where they.. and me aswell .. suprised to see the top speed only be 3 miles slower.
While testing the top speed one of the riding mates pointed at my pipes.
After pulling over he screamed: your pipes where glowing red hot!
Now i know jetting doesnt change because of different tires.
Bike has been a bit rich since day 1.
But since the banshee revs till the redline in 6th gear now, and i mean redline.
Can it be that i'm running lean(er) @ those high revs?
Currently running a 40 tooth sprocket, i think ill change to a 38.
Thanks for any comment in advantage!
No backfiring at all.
A clean rev up to the verry last rpm it can do.
real smooth.
like a downhill 4th gear WOT on a normally geared banshee.
For mods:
Pipes + modified airbox lid (stock air filter)
290 main 4th clip on needle
not sure on the pilots but that wont be an issue here.
Stock ignition timing.
Both headers glowing red for a good 5"
Absolutely!! Do a plug chop and see what it reads. Get back with us on it.
How long are you holding it open?
Are you doing this at night?
Did this at night and was holding it open for 10 seconds.
So thats 10 seconds at the point where it did not rev any higher.
And i promise to never do it again ;)
421297[/snapback]
my headers on my mustang would glow after a run on nitrous, but I ran it rich on the fuel side to be safe,
I think too much fuel and not enough air to cool it down makes the exhaust hot, and to much air and not enough fuel melts the piston. blah,blah,blah... good luck
:bolt:
