royxc800 Posted September 26, 2005 Report Posted September 26, 2005 Those of you that tinkered with your front shocks what rate are you using and what type of ridind do you do. I weight 170lbs and am looking for a spring that will provide a plush ride for trails.I am putting different shocks on but need to find some springs and need to know what spring rate to go for. Thanks Mike Quote
sj820 Posted September 26, 2005 Report Posted September 26, 2005 Buy a set of YFZ450 shocks off ebay for around $200. If you want to play with your shocks the ones that come on the 450's are completely adjustable. Preload, compression and rebound. When I put the shocks on my Banshee I adjusted the preload so I have a nice amount of sag in my front shocks. These shocks are way better than the stock Banshee shocks.The only thing I had to do was take my dremel and remove some of the steel around the upper front shock mounts in the front. Mind you that I did this with a freshly powder coated frame so I was careful not to make this noticeable. Cant even tell that I did this. Definitly a good upgrade for the $$$. I have seen them go for as cheap as $150 and for more than $300. Just be patient!!! Quote
