When I gas it even a little it dies put new plugs in and air filter is clean?
It will ideal fine and sounds good untill you gas it and it (BAWGS DOWN AND DIES)
I just got this thing, So am new to the shee's
Thanks
myself i would say tors
unplug the connectors on the carbs, and the black box attached to your frame above the left cylinder
i forget if you have to unplug the parking brake one too to completly disconnect it
Ok guys you have been great, I got her running again I have a single crab set up. what was wrong was the pin at the end of the slide fell out so was an easy fix!
So till next weekend banghead LOL
