1" is the smallest i know of also. but if i were you, thats what id get. then you can run a hi-mis spacer and get more articulation out of the joint, and not sacrifice any strength. check out here, http://www.kartek.com/products/all/heims/heims.htm that place is a lil high, but carries some really good shit. and being in socal i dont think youll have a problem finding the store. mckenzies also stock these types of things.
You need spherical bearings, uniball is just another name for them. They come in all kinds of sizes starting @ com-3t is a 3/16''. If you want what roll design uses, you need a com-12t , that is a 3/4'' teflon lined bearing. If you are going to use high misalignments you need a com-12t wide it has diffrent dimensions than a com-12 t. go to www.rodendsupply.com or www.fkbearing.com
