BrockMoto Posted September 22, 2005 Report Posted September 22, 2005 (edited) I do not have very good compression in the right side cylinder I ran a test and its fine on the left but its about 25psi on the right it is hard to start, pops while idoling, but seems to run alot better when i get into the higher rpm's Does anyone have some advice on what to do? Colin Edited September 22, 2005 by SheeRider105 Quote
Motoman991 Posted September 22, 2005 Report Posted September 22, 2005 take the jug off and see whats up, you probably need to rebuild the engine Quote
BigRed350x Posted September 22, 2005 Report Posted September 22, 2005 Time to pull the head and check everything. Also, if you only have 25psi, don't be out running the damn thing, it will only make whatever the problem is a lot worse. Quote
[email protected] Posted September 22, 2005 Report Posted September 22, 2005 its simple , simply blown time for bigger pistons and porting and rechambering / shaving the head Quote
