I've also used Valvoline and Havoline.. 10w30... used to run 10w40 in my warrior.. neverhad any problems with either.. Just felt like switching for the sake of doing so and now im using Bellray Gearsaver 80w90 i believe.. anyways all seem to work great for me... I also switched from 50/50 water/anti freeze to Engine Ice once i put my pipes on.. It does lower the tempeture of my bike.. but by how much im not sure , just know that i can ride alot longer on hot days without bogging like it used to.
my 2 cents
B-rad
I tried Golden Spectro and Bel Ray. The Golden Spectro is much thinner eve though it claims the same weight. I even mixed them together once heh.
I must say I will only be buying Bel Ray from now on. The golden spectro would cause my clutch to start slipping if I left it in more than 2 trips.
