bigboybanshee Posted September 5, 2005 Report Posted September 5, 2005 So what do you guys run (suspension) on dirt for dragging? Would a solid strut setup be too stiff or would I be better off running a shock/spring? I'm open for any suggestions, not too sure what would be ideal for dirt. Thanks!!! Quote
RNBRAD Posted September 5, 2005 Report Posted September 5, 2005 A smooth track you will get better times with struts, a rougher track you will get better times with a nitro or sprung shock. You can even get the Marvins where you can adjust the nitrogen compression for different tracks. Quote
bigboybanshee Posted September 6, 2005 Author Report Posted September 6, 2005 A smooth track you will get better times with struts, a rougher track you will get better times with a nitro or sprung shock. You can even get the Marvins where you can adjust the nitrogen compression for different tracks. 411844[/snapback] I was thinking about going ahead and investing in a set of marvins here soon, being that right now I have 3 options for tracks (asphalt, dirt, and sand). Switching back and forth between the shocks and the solid struts for one race at a time would become a PITA Thanks man! Quote
