The factory spark plug gap is .028-.032". As long as you have not changed your compression ratio, the overbore on your cylinders shouldn't affect the spark plug gap. I'm trying to remember the metric equivalent, it's like 5-7mm or something, but I'm positive on the .028-.032" I usually run mine right in the middle of the range, at .030". Be sure and check the plugs out of the box, they may very well need adjustment.
