marjeneef Posted September 4, 2005 Report Posted September 4, 2005 Please help new to this, I have a 02 banshee, I have done the clutch on it 2 times in the last month, I fixed it went to the dunes rode for about 4 hours then no clutch, came home tore it apart put in all new friction plate and metal plate and 3 new springs new adj. screw. rode up and down the street worked fine went to the dunes again rode for about 4 hours and then no clutch. Plates all bad, adj. seems fine but what about push rod? How do I check to see if bad, Please help thanks Quote
FASTOYS Posted September 4, 2005 Report Posted September 4, 2005 Do a search on our FAST Racing clutch and give me a ring on Tuesday ! I can get you fixed up!!! Quote
itsaripper Posted September 4, 2005 Report Posted September 4, 2005 Drain the water again. Take off the side cover. In the middle of the clutch is the clutch ajuster, a 10mm nut and what looks like a bolt with no head but instead has a slot for using a screwdriver. Take it out, use a magnut and take the steal ball out, then use the magnet again, and get the pushrod out. If it is bad the ball and the rod could be one. If really bad they will have mushroomed and won't come out. What kind of oil are you using in the trans? Quote
marjeneef Posted September 4, 2005 Author Report Posted September 4, 2005 Thanks for all teh help The ball bearing and the push rod are welded together and will not come out, I dont have to split the case do I, not really that mech. Is there another way Quote
