alright well here is the deal guys.... i revently put my motor in a a arm frame cuz it was a j arm... anyway i reconnected the wires i disconnected... and i put a set of pipes on it.... well i went to start it right when i got the pipes on and it would not start.... i choked it.... i put some either in it.... and this thing will not start..... i have no clue what is wrong i just want to idk :cry: anyway if anyone has any idea's why this is doing this please let me knoe... it has been sitting for about 3 weeks now but idt that shuold have done it..... could it be that my jetting is too lean.... please give me some idea's on what this might be...... im almost considering take it to the d word...(dealer)
fuck the dealer, and dont cry either. :D
i dont think the jetting is an issue. you need to check for spark. and is your fuel turned on? :shrugani:
BTW, steer clear of the ether. its not very 2stroke friendly.
Edited by gimmeabeer
also check your wiring because if you transfered it from the other frame there may be a ground wire that isnt hooked up or making a good connection, worht checking that out since it is usually the tiny things that give us the most crap.
ok i stil have stock jetting in it and i was told to run jettings around 280-310 area....that is almost 10 size's bigger... could jetting be the issue.... and gas is on tried it on both reserve and on
also i only found one ground wire and thats right on the bottom of the screw eith a wing nut... idk ill clean that off again.....
i didnt have much either so idk... with the exlectricals i barly disconnected anything... i only disconnected the rear... oh well later tonight or tomarrow ill check for spark...keep the ideas coming guys
If all you changed is the frame, the jetting should not change. You dont have pipes and your Bored out to 383? Thats a little crazy :confused: If you dont have pipes 280-310 on the jetting is a little crazy :shrugani::shrugani:
401374[/snapback]
pull the hose make sure you have fuel, pull the plug and make sure you have spark, make sure all the clamps and screws around the manifolds and carbs are tight, make sure all the elec clips are tightly "clipped" together, make sure the choke tube is in there, ckeck to make sure the slids are sinc'd and not hung open or the idel screw to far in, and check to see if the key or any other kill swith is turned off.
Personally I'd pull the carbs put in a 30 pilot and 310 mains, and clean everything!
If all you changed is the frame, the jetting should not change. You dont have pipes and your Bored out to 383? Thats a little crazy :confused: If you dont have pipes 280-310 on the jetting is a little crazy :shrugani:  :shrugani:
401427[/snapback]
i got some paul tuners there buddy... and alright ill double check for spart tomarrow... they said i wont have to change my piolets.... and the choke tube? woudl that be the choke itsself... cuz thats there... hummm.... htis things makeing me angry banghead
401542[/snapback]
No, the choke tube is a rubber hose that goes between the two carbs, it connects the choke to the other carb and without it you have a huge vacuum leak.
You will need to change your pilots! and start with 310's!, trust me i've used these pipes personally.
401550[/snapback]
how do you know how to corectly jet for pilots?i know hot to do a chop plug test but i never changed the piolets... oh its there... only took the carbs off and put them back on
