Ok so I finally got time to start the installation of my top end. I ended up buying Wiseco pro lite pistons. NOw that I have everything together do I need to put some sealant on the gasket mating surfaces for the base gaskets and head gaskets?? If so what kind? I know 2-strokes are picky but I'm not sure just how picky they are. I know if I was putting a engine together on a vehicle I wouldn't second guess, I'd do it. Just thought I'd ask before I got it all together and it started leaking everywhere, better safe than sorry.
Edited by Handyman
Yes you need some on the base gaskets. I do a small bead on the matting surface facing up. Just make a bead where the gasket would contact the cylinder. Use Yamabond 4. That should be the one that stays flexable. Hondabond is a bit better, its a little more sticky. As for the head i have an o-ring type head so i cant help ya there :(
Good luck
Anyone else please correct me if im wrong :blink:
