i have a motofast 2 into1 pipe and it seems to get pretty hot is that normal compared to other aftermarket pipes or does the single get hotter thank hqers :cheers:
im workin on my jetting maybe that is the prob banghead
Your jetting could definitely be the problem but also take into consideration that two cylinder's exhaust is getting pushed through one pipe, so I would imagine it should be hotter than if you were running two pipes. Granted, I'm not sure how much hotter it would be but if you're jetting turns out to be right and your bike runs fine, I wouldn't worry too much about it. JMO :cheers:
