I just finished putting my shee back togeather. It runs fine, I havent really gotten on it yet though.
Question, I was just thumbing though the clymers and was reading abou thte rings. I just put them on. I didnt look at the different thinckness. Should I tear it back down and double check? What will happen if they are reversed?
Thanks
Well, you've got a 1 in 3 chance of having them correct. ... Both pistons right, both wrong, or one right and one wrong. The odds are against you!
You should be able to tell 0.45mm (half a millimeter) by sight through the exhaust. ... They're obviously made like that for a good reason, and I would imagine you'd have problems if they're not correct.
Are they original style pistons that you've just changed the rings on. ... I know with my Wiseco prolites, it didn't matter what way up or which ring went in which groove.
Rare.
I took the cylinders off to check. I had them both right. I did notive a little wear on the intake side of the cylinder. Is this normal? 22 cm domes 130 lbs at 1000 ft above seal level. Sound right?
namura pistons
