Hey everyone, haven't had as much time to dwell on the HQ lately due to a new work shedule, any way I noticed my 2 rear tires are starting to wobble alittle at speed. Could it be worn spindles? whan you lift the rear off teh ground and move the tire/rim on teh axle side to side there is some play, just not a shitload. I also have 2 1/2 spacers on(stud type). Could they being sightly out of whack cause this as well? My axle is stock, spindles are stock plus the spacers. Any ideas??
Duh onmy part, the nuts were alittle loose, i took off teh spacers but now am missing the huge width gain they gave me. Im thinking about a aftermarket +4 axle, How hard realistically is it to install and how long should it take?
Edited by racer714
To install an aftermarket axle, easy. Just takes some time taking spindles off and your axle nuts ( thats going to be the hardest part if they haven't been touched for awhile) it shouldn't take you more than an hour.
If you cant replace an axle in an hour or so, you probably should not be working on your shee.
392886[/snapback]
ok chapmanmd, stop bustin my balls, where the hell is Swansea, Illinois anyway?? We shoudl all plan an IL ride b4 winter!!!!!!!
