80overShee Posted July 11, 2005 Report Share Posted July 11, 2005 I've heard that removing the cross-over tube can improve throttle repsonse. Is this true? I realize boost bottles do absolutely nothing but what about the opposite direction of expanding link and instead removing it entirely? Quote Link to comment Share on other sites More sharing options...
sredish Posted July 11, 2005 Report Share Posted July 11, 2005 no keep it. you need it to equalize the intake pressures. boost bottles do nothing more than a stock crossover tube will, that's what they're talking about, but YES, you need your xover tube. Quote Link to comment Share on other sites More sharing options...
Holyman Posted July 11, 2005 Report Share Posted July 11, 2005 I just took mine out and I lost some of my low end and I got a hesitation at WOT. All I did was take some 5/8" diameter round stock and cut it 1.5" long. About 1/2" will be sticking out the top of the rubber boot. If you don't like it, put the tube back in. Scott... you run a 2:1 right? What are your engine mods again and what kind of riding do you do? As I recall you are running the Keihin 35MM correct? Quote Link to comment Share on other sites More sharing options...
sredish Posted July 11, 2005 Report Share Posted July 11, 2005 Scott... you run a 2:1 right? What are your engine mods again and what kind of riding do you do? As I recall you are running the Keihin 35MM correct? 391093[/snapback] I used to run a Trinity 2:1 setup. It has a crossover tube milled into the billet intake internally. I sold the Trinity stuff and got a Graydon intake and a new 35mm airstryker. Well, damn thing wouldn't run, kept dying out on the left side. No electrical issues, no carb issues, no cylinder issues. Turns out, the bike wouldn't run on the left because the intake has no equalizer, no crossover tube or anything. So, the vacuum from the right cylinder was stealing from the left and the left wouldn't run for shiz. Took the Graydon off and put the stockers back on (with xover ) and it ran absolutely perfect. So, I'm getting a crossover tube tig welded into the Graydon intake as we speak. Scott Quote Link to comment Share on other sites More sharing options...
Holyman Posted July 12, 2005 Report Share Posted July 12, 2005 You're getting a crossover tube welded into a Graydon 2-1 intake? Quote Link to comment Share on other sites More sharing options...
