well.... i have read my jettings and the eemed to be cofee brown and a little itsy bitsy black bit i think thats ok but... after i checked my compression
the left cyl had 150~155 and the right one had 160
what could be wrong the motor seems to run great but just that it wont get to 130 kmh.... i dont know why when the motor was weak it used to get 130...kmh now it just gets to 127 like that...+ my banshee has a v-force 3 now
Compression sounds good bothh cyls should be within 10%of each other which they are.With the temps your running in you may need to go slightly leaner on the main during summer to compensate. You say the plugs are black which means you are running rich :cheers:
