Rare Scottish Tree Badger Posted July 18, 2005 Report Posted July 18, 2005 i actually started my bike this weekend without using the choke whatsoever, and it idled first kick and from there no problem. temp around 10-25 C. This normal? also have you ever heard abouth the 2-stroke oil that i mentioned? is it any good? At 10 degrees C you should be using the choke on the first notch, and at 25 degrees C you should be on the verge of not needing to pull the choke at all. I think you're rich on your pilot circuit. ... How many turns are you out from seated on the air screws? As I said above, you should be in the range of 1 1/2 to 2 turns out. You should need to use the choke (on the first notch) at ambient temps of under about 25 C. ... I know I'm rich on that circuit 'cos I can start the bike at 20 C without the choke. ... Below that temp, using the choke, within 5 seconds or so of being fired up I can put the choke off and it'll idle fine. I don't know anything about your oil. Rare. Quote
namshee Posted July 19, 2005 Report Posted July 19, 2005 At 10 degrees C you should be using the choke on the first notch, and at 25 degrees C you should be on the verge of not needing to pull the choke at all. I think you're rich on your pilot circuit. ... How many turns are you out from seated on the air screws? As I said above, you should be in the range of 1 1/2 to 2 turns out. You should need to use the choke (on the first notch) at ambient temps of under about 25 C. ... I know I'm rich on that circuit 'cos I can start the bike at 20 C without the choke. ... Below that temp, using the choke, within 5 seconds or so of being fired up I can put the choke off and it'll idle fine. I don't know anything about your oil. Rare. 393887[/snapback] tks, i'll let you know how it goes. Quote
MILO Posted July 20, 2005 Report Posted July 20, 2005 i'll have to try the trick of spraying around the boots and reed cages and see what happens. i have pc pipes and silencers, pro flow foams w/o the lid, around 1200ft,needle at 4th clip, and running 360 mains. that's just what shee liked to get a nice little ring with the plug chops. there are way to many variables to say exactly what any jetting should be at. do a plug chop and put in what makes her happy Quote
