jlh Posted July 7, 2005 Report Posted July 7, 2005 When riding the left side smokes a little more than the right? Should I put new rings or let it be for a wile. It's not a lot of smoke and it runs great, just a little smoke Quote
watkins Posted July 7, 2005 Report Posted July 7, 2005 Whats your compression on both sides? I think you are seeing normal banshee behavior.. mine does that too. Quote
jlh Posted July 7, 2005 Author Report Posted July 7, 2005 I have not done a compression test yet I will do that this weekend to see what's up. Quote
DBLtapS Posted July 7, 2005 Report Posted July 7, 2005 Sounds like an air leak. Idle, spray starting fluid in short bursts over the weak points of the engine. I found an air leak this way on my carb top. Piece of junk T.O.R.S.top was cross thread. Keep you hand on the kill switch...... Quote
