whats up guys. i just did a topend on my shee over the weekend. everything seemed fine. babied it for a couple of hours yesterday. then at wot it ran great. today i took it out and it seems like it falls off on top. also breaking up alot. i was thinking reeds. but wanted to double check here first. i am going to pull the reeds out tomorrow,if you guys think this could be the problem .does anyone have any reeds laying around they want to get rid of, of course if this could be the problem. thanks for the input
Pull the plugs. ... Do they tell you anything?
Rare.
383898[/snapback]
i just put it away. was kinda pissed off. i am going to pull the plugs and possibly other things tomorrow. providing work goes normal
A couple things....
Make sure carb tops are tight.
For testing purposes you could unplug the tors box under the gas tank on the left side. It's a little black box.
Carb slides need to be in the proper carb. The cylinder shaped slide has a cutout..it needs to face the airbox.
Choke tube needs to be between the carbs.
The carb bowl with the choke tube in it goes to the carb on the left.
Make sure the carbs are synced.
Make sure you don't have an airleak. Spray starting fluid or wd-40 around the carbs, read cages, base gaskets and head to see if the rpm changes by burning the spray of your choice.
Those are some of the common things. If you have a compression tester, test the cylinders just to see that a ring didn't can't on a port.
my carb tops were conviently stripped by the previous owner. i put teflon and loctite on them but . i need new ones.
384285[/snapback]
Is that what fixed it or is that just something you came across.
