sampleba Posted June 19, 2005 Report Posted June 19, 2005 Im debating wether or not i sould take off that air box snorkle or not. Without it the thing really rips and the plugs look ok so is it still an ok thing to take off? I have no mods except a boost bottle. Thanks for everyones imput in advance! Quote
badassbanshee479 Posted June 19, 2005 Report Posted June 19, 2005 If the plugs look fine I would leave it off. most banshees come jetted alittle rich from the factory so you should be fine get some pipes and you will think you have a whole new machine Quote
sampleba Posted June 19, 2005 Author Report Posted June 19, 2005 If the plugs look fine I would leave it off. most banshees come jetted alittle rich from the factory so you should be fine get some pipes and you will think you have a whole new machine 383470[/snapback] Thanks but how tough is it to find the right jetting when u put an exhaust system on it? Quote
scotts96fast Posted June 19, 2005 Report Posted June 19, 2005 Thanks but how tough is it to find the right jetting when u put an exhaust system on it? 383475[/snapback] most pipe kits come with the correct jetting if you have no other mods.I just bought a set of fatties and they came with mains.Your boost bottle and taking the snorkel off,you'll should be fine. Quote
Banshee~ Posted June 20, 2005 Report Posted June 20, 2005 most pipe kits come with the correct jetting if you have no other mods.I just bought a set of fatties and they came with mains.Your boost bottle and taking the snorkel off,you'll should be fine. 383478[/snapback] Some come with "perfect jets", but I would still do a plug check after you get it back together. I would go up a size on the mains if you took the snorkel off. Before you get pipes get a good airfilter (the more you clean your airfilter the longer your top end will last). Quote
DuneRoller Posted June 20, 2005 Report Posted June 20, 2005 Quite a few people here can get you really close just by knowing the mods you have. Quote
