I have a 96 shee with fmf fatty pipes+stock silencers, k&n with no airbox and i put in 260 main jets and it never seems to wanna get on the pipe and it sort of just sputters... I cant think that at my elevation i could use a 300+ jetsize so i wanted to see if anyone else here was around my elevation and wanted to see what mine they are running.
I hold it WOT and it just stays in midrange right on the edge of hitting the pipes but just never gets there
Also maybe thinking this might be ignition related but the bike ran good before i added the filters, pipes, jets.
Thanks guys
Edited by badazztoyz
have you done a plug chop to see what it looks like.
what needle clip you running also.
I run Toomey's T6 with a 2 into 1 filter system and +4 timing...I have a 270 mains in mine and runs great.....I am at 4800' feet in colorado....good luck..D
My dad runs a set of fatty's with a K&N and is running a 270 with a dial a jet. Most of our riding is at about 2000 feet, but we also go to Sand Mountain NV which is at 4000 feet. He only changes the dial a click or two and it runs great...... :cheers:
I usually start around 270-280, I'm currently at 290 I'm at 5000 ft
383777[/snapback]
same here, when i had stock carbs i was at 280-290 with same mods but i had toomey silencers, should be the same , i live in new mexico.
I think your jetted rich. I run 240 mains with k&N pod filters, fatty pipes, port/polish. try going down to about a 220-230 main
383624[/snapback]
I think he is runing stock carbs
I am running the Toomey needle and stock pilot....My bike had a hard time until I turned the air screws in all the way and then out a half of a turn.....runs great at 4800' and 270 mains...Grand Junction, CO. D...
