momo20 Posted June 2, 2005 Report Posted June 2, 2005 can some please post so pics of what i am supposed to do with that clip...thanks and where its located Quote
Wallrat Posted June 2, 2005 Report Posted June 2, 2005 You should have a little black pull knob on the left hand side carburator. Lifting it up will help start the engine. It has 2 positions, usually for general starting just use the first position. If its really cold outside then pull it all the way out and then start it and push it in to the first position after 10-15 seconds. Just make sure you push it all the way down b4 u start riding. Quote
ke398 Posted June 2, 2005 Report Posted June 2, 2005 Cruise over to http://www.yamahaaccy.com/parts.aspx. It has exploded views for for almost every part on your bike. You can also get your oem parts there. Hope this helps. Quote
